Displays on the remote speaker the ORF lists received and installed from the local speaker for installation and outbound route filtering for IPv4 and IPv6 address families.
| remoteaddr | Specifies an IPv4 address that identifies a BGP neighbor. |
| ipv4-unicast | Specifies IPv4 unicast routes. |
| ipv4-multicast | Specifies IPv4 multicast routes. |
| vpnv4 | Specifies VPNv4 routes. |
| received-orf | Displays on the remote speaker the ORF lists it received, and subsequently installed from the local speaker for installation and outbound route filtering. |
If no address family is specified, IPv4 unicast is the default.
ORF is only supported for IPv4 peers. If this command is executed for an IPv6 peer, the command is rejected with the following error message:
Outbound-route-filtering not supported for IPv6 peer remoteaddr
The following example shows the ORF filters received by the remote speaker:
show bgp neighbor 11.0.0.2 received-orf
  Address family: IPv4 unicast
  Prefix list:
    nlri 21.0.0.0/8    exact             permit
    nlri 22.1.0.0/16   min 24 max 28     permit
    nlri 23.0.0.0/8    min 16            deny
Community list:
Extended-community list:
    rt:100:2                           permit
    rt:100:3                           permit
    rt:101:1                           deny
        This command was first available in ExtremeXOS 15.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the L3 VPN feature, see the Switch Engine v33.1.1 Licensing Guide document.
